Need a little help with injectors
OK ran some FPPF and Stanadyne in the tank cleaned the injector and no more injector knock! Keeping fingers crossed I must have gotten some debris in the injector when installing it? Thanks for all the input and help! I took a video of the injector knock for others looking to see what it sounds like...... now if I can figure out how to put it one here?
Oh and by the way a 30mm axle nut socket for a front wheel drive is perfect for removing injectors. I found alot of people asking what socket to get when I was searching injectors. Just thought I would add that. If not its GM specialty tool J-29873. Trust me the axle socket is much cheaper.
The knock is probably just air trapped, it should run out (probably gone now).
The axle socket is nice, buit 1/2 drive, and no wrench accomodations.
The speciliazed socket is worth its price as it takes a 3/8 drive, meaning less room to use, and has wrench accomodations meaning it will work in even tighter spaces.
Glad your issue is resolved.
Either that or your local rebuild shop for the nozzles.
Hmm is Kenny gonna buy a tester? :D
Cheers
Nobby
Thinkin about it. Saw some made in india ones for 149$ on ebay. Why not, they make the nozzles....As far as Badger Diesel goes...They did the IP on my Dually and I think it has issues. From now on for me, unless I learn to do them myself, local shop only. This way I can personally represent my disdain if a part is defective...
