I had an injector leaking where the injector treads the two sections of the injector together. I got a new bosch rebuilt injector got it installed and dang if it at leaking at the same place! Pull it back out and almost busted a blood vessel tightening the injector sections. Put it back in and still small leak. Is this a common problem with injectors? Can you use rtv on the treads to seal them? :mad2:
