kojo
diesel head
I think it is 239.29hp And kuutio's 195kW = 265.13 horsepowers
Nice numbers Kane, for those of you that don't do metric here are the conversions
453.23194073071653 foot lbs at 3500 Rpm
258.71313672989 HP at 2500 rpm
Very nice numbers from a 6.5
Just curious, intercooler with ATT... if ATT will give more power, would IC give few horses more with it?
My IC dropped IAT's 190F to 104F (temp outside ~60F)... ATT is not that "cool" is it? :smile5:
Personally, cooler is just a thing to give more long life... nice of course if it gives more power :smile5:
6.5quest, what's your secret... over 300 rwhp :yumyum: :thumbsup:
Ian, do you think 50+HP of that was the 'drugs'?
While the discussion on this forum has sometimes tended toward yes/IC for turbo X, no/IC for ATT, the overriding factor is really what peak & sustained boost pressure a given setup runs. As you've probably experienced doing your own setup, our trucks do make plumbing/fitting a good system more challenging than the OEM IC equip'd pickups.
Compressor efficiency differences do impact outlet charge air temps, but temp increases due purely to compression are the biggest factor in charge density.
One of the better charts I've seen illustrating the relationship is in Turbo - Real World High-Performance Turbocharger Systems, from SA Design.
Here's a link to 2 pages - showing the relationship btwn boost & density ratio (how much the compressor increased charge density above ambient air pressure).
http://paceperformance.com/ProductImages/manufacturer/cartech/pdfchapters/sa123chpt3.pdf
The 2nd chart shows the relationship with aftercooling & how much charge density the aftercooler regains.
The book goes on to include both charts overlaid, which makes the difference much easier to see, but I couldn't find an online source of that page. To get the idea, just go to a few boost points - say 5, 10, 15, & 20 on the non aftercooling chart & note the density ratio for these 4 points. Then go to the aftercooled chart & note the density ratio of the same 4 points.
For those wanting more IC discussion, here's a link where you can download a useful primer on IC's from Spearco:
http://www.turboneticsinc.com/all_about_intercooling
I have a WMI waiting to be installed, and now that I understand from Bill that any "clean water" can be used I'll be plumbing mine in sooner than later, I had been mentally preparing/operating under the misconception that it had to be pure water, or bottled etc., but regular "city" tap water will be sufficient.
