I am so sick of poor quality parts these days it's not funny anymore, not that it ever was....
In the last 5 years I have had to remove the manual tranny & transfer case a couple times due to poor parts. Most of the time the clutch fork is bent. This could be due to a cheap pressure plate, warn pivot ball, poorly made fork, etc. Not once has it been the master or slave..
Well the dually has been down for a few months now, yep, clutch won't work, so with a new tranny on the way it's time to fix this stuff, or attempt to...
I ordered a new master, slave, braided stainless steel flex line from a custom shop in TN, I already have a adjustable push rod for the master cyl, I have a new South Bend clutch here and I use the bronze pilot bushing and a new one will be going in..
With the p400 almost finished it's time to get other things ready as well.
So I got the "new" clutch fork from rockauto, they all are made somewhere else, go figure, it arrived and had a really thick coat of paint or something on it, I know where the forks bend so I took a good look, saw what looked like a small notch in the metal under the paint, so I burnt it off and sure enough, cracked in a bend....
So I cleaned it up and decided to mod it and see if I could "fix" it and get it to last a bit longer.. I took a couple pieces of 1"x1/4" flat bar, shaped it and welded it to strengthen the fork.
Next was the throw out bearing, years ago you could buy them in different length"s to get the correct 1/16" clearance to make everything travel to give a good clutch release and lock up.. Theirs a way to measure things before mating the tranny back to the motor, but I'll leave that out for another time unless someone wants to know...
I bough a "adjustable" heavy duty bearing from Novak, this will enable the clutch to be fine tuned to give the correct travel in the pressure plate..
I'll have the tranny in a couple weeks, once I get things replaced I'll update how the plan turned out..
A few pics of my fork mod...
