dbrannon79
I'm getting there!
From what I recall, once it's been cleaned and reinstalled, you will need to connect the scanner and reset the ECM so it will "re-learn" the engine. I was told this a few years ago that the ECM will over time compensate for the build up and adjust how it runs. I had one that was so bad that after I cleaned it, the engine wouldn't run right. kept stalling at idle. even though there was no codes on the ECM, after resetting it, it ran like it was new again!
