Missy Good Wench
Wild Blonde from Cloud Mt
Ok boys
Hang onto your Butt
Missy has decided to return to the good O'l days with her 91 Burb.
Got the plan all sorted out now and went out yesterday and bought some goodies to play with.
I am tired of electronics that fail and trannies that fail and lights that blink and all that sort of thing.
Decided that along with the 6.2 diesel coversion into the 91 that I am going to install a real jewel of a tranny and T case setup.
OH yeah buddy
Went out yesterday and bought a TH350 coupled to an NP 203 T case.
Yup the old FULL TIME sucker.
Found one from a 1976 Chevy 1 ton thats in fairly good shape. The Tcase seems fine but the tranny had issues with second gear.
Missy can fix it. :thumbsup:
With 35 inch tires the little 350 can do the job sweet and highway RPM's will be around 2150 at 60 MPH.
I dont really do much long haul driivng anymore so the need for an OD is not an issue.
Actually my 94 Burb with the 4L80 will spin along at around 2100 at 60mph even with the OD (stock tires and 4.10 gears)
The TH 350 is a damned good box in my opinion. Been through many in my time and have seen these little suckers take a beating behind even a 454 and live to tell about it.
The venerable old 203 box with the all time drive is a sweet setup.
Hardly ever need to touch the T case shifter unless it really nasty.
The interaxle differential keeps power flowing to all four all the time.
On road handling is superb especially on such things as loose footing (gravel roads)
Been dreaming about doing this and the time seems right.
Little if any issues to getting this tranny T case setup into the truck.
Little mods likely to the floor for the older style shifter.
Addition of a vacuum switch to run the modulator.
Drive shaft mods to fab a non slip yoke rear shaft
Scrounge up a CV jointed front shaft. (Blazer, Burb pickup 73-79)
The one issue I am pondering is the easiest way to get a signal to the electric speedo in the 91 dash.
The 203 has a cable driven speedo.
I may be able to do some machine work in the back housing and install the reluctor ring from the 241 and then modify the housing to accept the sensor.
Not an insurmountable obstacle but will keep Missy thinking for a while.
Called a few places yesterday and the answer varied from NOT DOABLE to WELL I can sell you these goodies here for a BAzzzilion $$$ and it will work.
Worst case scenario, use an older style speedo and install a cable
):h
Once all done this little setup should be sweet.
The 203 and the 350 were never used with a 6.2.
I swapped a TH350 into an 82 K Blazer with a 6.2 back in the late 80's
700R went splat all over the street and the goodies to make a 700 were spendy $$$$$$$$$$$
and used ones tough to get (Cheap)
Used a Transdapt kit to keep the T case in the same spot (700 is longer)
Ran that box for a loooooooong time
In that setup I kept the 208 T case.
This time I want to go for the gusto and put together what I consider the best of the lot as far as reliability.
The little 6.2 may not be a rocket but they were reliable.
The TH350 with a good shift kit was very dependable and well not quite bullet proof but close.
The NP 203 T cases were darned good. The chains would on ocasion give trouble but when left stock (without part time mods) these boxes were very tough.
This package when complete should comprise some of the most dependable components that GM ever offered.
The 91 Chassis was the best of the OLD (Brick/Box) body style.
These trucks had the nicest interiors of the style. The accessories were mostly trouble free.
The heater controls were very basic with little to go wrong.
The dash is easy to see and had little in the way of troubles as far as the intruments go.
Seating is roomy and comfortable and the visibility for the driver is acceptable.
The ride with the front/rear leaf springs is not at all bad but not the cushies that many have come to know on the GMT 400 and 800 trucks.
Durability of the front axle components is far better than the IFS stuff.
Cheap to fix and very tough
Now for the best part
This rig when complete will not have a need for a computer to make it go.
Many will find fault with this build but thats ok, I have always marched to the tune of a different drummer
So in a few days I will go pick up my 350/203 heap and drag it home.
Yessssssssss
Missy is happy now. Got a pile of fresh scrap iron to play with.
MGW
Hang onto your Butt
OH yeah buddy
Yessssssssss
MGW
