Paveltolz
Доверяй, но проверяй
Decided to start a separate thread since this 'what did you do to your 6.5' episode is getting drawn out.
So, What did I do to my truck's upper intake? Almost FUBAR;d it but, "Hodge Podge for two hundred Alex" and discovered several solutions in order to un boo boo this thing.
Issue: While completing another project that required the upper intake's removal, I discovered that two of the studs (with my set up, I chucked bolts a long time ago) weren't going to torque to 17lbs and were, in fact, going to just pull out. I tried longer studs but, only one got better and I didn't trust it.
I chose to use the Heli Coil thread repair kit as I’ve had this issue occur in the past and this technique worked fine. However, I inadvertently grabbed the M10 x 1.5 kit from my stash. Drilled out the bad threads; tapped the holes with the provide tool; inserted the coils; did a test fit with the M8 x 1.25 studs aaaannnndddd…yeah, not happy with myself. I double checked the tool drawer and I didn't even have an M8 kit anymore.
I have done this repair before to a couple of other lower intakes and discovered that two other holes in this one were already done. Guess I used it up and wither tossed or loaned out the kit to someone else. Probably 635 who's no longer on here so I'll blame Ted. Hindsight right?
Now what? After talking with my machinist friend, whoI recommended using Time-Serts, EZ Lock or something similar like a thread repair / resize insert.
I did some research and the Time-Sert pages didn’t give me the outside diameter size and pitch and I wanted something I could just screw into the two now M10x1.5 helicoils that weren’t going to back out without themselves being drilled out.
Google Searched and sourced Patikil and Luoring thread repair / resizing inserts from Amazon as they had them in the needed M10 x 1.5 Male. and the OEM M8 x 1.25 Female and they were stainless steel.
Still waiting on the Patkil units which are 20mm long vs the 12mm long Luoring's which would fit the middle hole. I decided to just do all of the holes since I'm constantly changing things up with intakes, Turbo's, Injectors etc. Discovered that one middle hole and another corner were already Heli Coiled (guess I did use up the old kit as I found another repaired hole on my other unit.
The Luoring's threaded nicely into the newly resized M10 holes using 3/8" wide flat bladed screw driver. (Note, different intake used for demonstration)
I drilled and tapped the remaining two holes with some challenges.
1. The drill bit into the aluminum and snapped in half on the second hole!!
2. The tap just wasn't cutting it. Literally.
I drilled out the old bit's remains using titanium drill bits starting with a smaller one and then a 7.9mm larger one that did the trick. I fought the tap into that hole to see how far I could get and realized some of the bit was still in the sides so I had to opt for a 12mm insert for that one. There were some more issues resulting in a destroyed insert and re-attempt at tapping the hole a bit deeper.
Yeah, I tossed the tap and picked up a new drill and tap set from Irwin at ACE Hardware. I'll use that tap to cut the other hole when the longer units arrive tomorrow.
But, it is in and looks fine. I'm sure using a 12mm long unit on the other corner would be fine but, they'll be here tomorrow and I can finish it up.
