I found a quick blip on one sight saying the epa is mandating the ck-4 oils meet the SN ratings as well, and that's the one requiring the reduction in zddp. Comp cams and lucas both make zddp additives. I saw a video done by amsoil rep about this, and he indicated that amsoil still makes a blend that meets the pre cj-4 levels of ch-4 for use in some older stationary equipment. Don't know how long they will make it, but if it is pre cj-4, it will have levels of 1400/1380 I believe. The only downfall is it won't have all the anti-soot additives in it that cj-4 on has, so you would probably have to stick with shorter drain intervals.
On the other hand, we had all the same doom and gloom over cj-4 oils back in 06, and people were screaming they were going to lose cams, valve trains, you name it, and we see none of that happened. I say if you'reworried, add a bottle of comp cam break 8n lube as it is concentrated zddp so it's not enough volume to thin out the actual oil much hindering the detergents and additives in the oil.
Having scuffed a piston on CJ-4, experienced "low oil pressure stop engine" alarms, and clearly noted CJ-4 was reformulated due to drain interval demands from fleet operators I suggest the Doom and Gloom is justified. Maybe not as much as predicted. The oil companies and the EPA are NOT paying to rebuild or replace the older engine their new standards won't protect. The oil companies are forced to try new technology by the EPA with emissions, not long engine life, as the #1 goal. Old technology engines are simply left to fend for themselves. Fleet operators are the test subjects and will take years to get the final formula hammered out. We are the test subjects as there wasn't much changed on the 2007.5+ Duramax, Cummins etc. except slapping emissions equipment on and, oh yeah, a different oil spec on a older engine design. (6.7 from a 5.9 is like a 6.5 from a 6.2...)
We run additives for our IP's due to ULSD's known lube problems. Hopefully corrected, but, now corrected with Biodiesel.
The biodiesel is a improvement to the oil, but, so what if you loose the valve train anyway. Biodiesel needs better water separators or a bad injector will ruin your engine faster than the oil. With the 5% or more Biodiesel showing up everywhere diesel engine owners are going to have to deal with it. Boat owner forums with it's bugs in fuel storage problems are ahead of most of us in the "hate biodiesel's expensive problems" arena.
UOA shows that Lucas Engine Break-in oil additive does add zinc esp for the flat tappet Cummins I have. The interaction with other additives as noted is the #1 concern I have doing this.
And then I notice AMSOIL is no longer playing the PAO base stock is better marketing game as their stuff may not be PAO anymore: "At the end of the day, the type of base stock used to formulate the oil is inconsequential; the product’s performance is what matters."
http://www.amsoil.com/frequent.aspx
After all I ruin oil and then suffer the effects. If it protects better why does Allison recommend their oil vs. the Dextron VI? I recall looking at the Dextron VI all over the back hatch of the Trailblazer SS with the 4L70E in it after towing the parts route a week: Yeah, marketing bullS%$# wrote a check that reality bounced. GM got to replace that transmission and blued torque converter under warranty. Hot thin oil has low pressure problems and won't hold a TC Clutch... I had to rent a vehicle the next two weeks because of the scuffed piston in the 6.5 and now a toasted transmission.
TBN was supposed to be a non-factor in CJ-4. I still watch it in UOA and it's still one of the life limiting items. TBN in fact was what fleet operators hit Shell with causing their Rotella to have a longer drain interval than synthetic T6 - because fleet operators are frugal and don't run synthetic. (IMO synthetic only has an advantage for high heat and load conditions.)
Simply put old technology and new thinner oils don't mix. The OEM's simply shrug and try anyway.
