6.5L
Old Iron Runner
So it has been a while since I have posted here so I thought I will share what I have been up to. Nothing to exciting but with winter coming and productivity grinding down I did have some videos from this summer of some testing I have been doing with my water/methanol kit. I know you guys like videos and it isn't really good evidence but in the videos I did the best to show the gains I do have. I know it is in the signature but the kit is a Snow Performance Stage III Boost Cooler running a 375ml/min and 625ml/min nozzles. Running -20*F Washer Fluid at the moment.
Before I mentioned before not many gains power wise from the system and EGT was not much lower. Well, turns out (embarrassingly) I had some bugs in the system. I got those since figured out and can report massive power gains across the board and a dramatic drop in EGT's.
During WOT max effort runs (like in the video) EGT's do not exceed 700*F. As far as power gains I am not a good estimate of power but I feel comfortable in saying torque is where the real gains are had with the much faster spooling of the turbo much lower in the RPM band (as you will see in the videos as well) I would say I have another 80-90ft lbs on tap. And I really am trying my best not to over-compensate that number. In fact enough gains that I am now needing a new clutch, major slippage
hello 375hp Southbend. Well, anyways, I do my best to not sound half stupid in commentary in the videos. Also, in the WOT video, I take a second to start because I was pulling off the shoulder of a gravel road and didnt just want to spin so I waited until I got onto pavement, but pretty much once I hit the throttle it was injecting, and yes, I know I short shifted 3rd a bit, and no, I didn't shitty shift into 4th, my tranny is just going out, it always grinds haha. I got a back up.
WOT RUN:
5TH GEAR WOT NO WMI 2500-2900rpm
5TH GEAR WOT WMI 2500-2900rpm
WOT RUN:
