Another turbo from our new vendor is in here.
http://www.thetruckstop.us/forum/threads/2000-k3500-gone-mechanical-build.42434/
The A-Team is best at towing and other sustained high load higher RPM use. Burnouts - No. You are trading low end boost for high RPM boost and pulling like a freight train all the way to red line. Getting to 2000 RPM where the turbo lights off is a big part of the trade off. The factory turbo rolls over and dies after 2200 RPM.
Getting around using a large turbo (ATT) for lower RPM:
http://www.thetruckstop.us/forum/threads/another-bd-quick-spool-valve-install-with-a-c.39716/
The other way of high stall converter is already posted.
Having run both the HX40II and the ATT I found:
HX40II lights off at a little lower RPM, but, from a dig needs to see 2000 RPM to really light off just like the ATT.
HX40II uses 24 PSI of boost to get the same power on the rollers that the ATT does at 15 PSI of boost.
If the HX40II Waste Gate pops off at high RPM you hit a brick wall for power and sudden smoke. - Adjustment is required.
Because the grades here are 7% to 18% I need all the top RPM power I can get out of the engine and have a blown a few up towing. So the large ATT is the best choice for me and adapted to daily driving that include steep grades.
Walbro is the best flow on fail lift pump you can get. (Engine will stay running with lack of power with a Walbro failure due to the IP's own pump.) They don't last forever. For the cost of a Raptor you can buy 2 or more Walbro's. If the Raptor quits about 10 seconds later so does your engine. I have run and killed lots of lift pumps - IMO the engine quitting with the unreliable things is the worst feature to have. Lift pumps are a question of "when" not "if" they die.
