JohnShead
I have had several incidents of not starting while hot. I was towed home a couple times, once I went back the next day and it started right up. I blamed it on the FSD so I got two new ones from Leroy and mounted them both to my heat sink so I can quick change. Since then it has happened several more times. I found on another thread that pouring water on the IP when this happens sometimes will get it to start. The last 3 times it did it, twice today, I poured water on it and it started right up but with stepper motor fault and very advanced timing, but I least I was able to get home. I have a clear line on the IP return and there are no bubbles. My grounds are good, all engine harness wiring connections have been cleaned up and tightened as I described in another thread where I was chasing IP codes. I bought this IP from S&S Diesel (I didn't know) about 100K miles and 9 years ago. Is it time for a new one or should I check something else?
