Good , that's what I'd do with my ported heads . I would do a " line of sight " with the runners . That looks like a lot of taper on the runners and very short for the intended RPMs . You'd be doing great if that causes the heads to only lose 5 CFM .
Those intercooler tops are cool, but you have the skills so why not make your own and save some money? Just get a nice brick and use aluminum sheet to make the rest.Well I have the runners welded up, I think they are too tall.
I have 2 different coolers to chose from below, only 1" difference in the height so the taller one would be my choice.
Low Profile HiRam Cooler, 2000hp
Gearheads are always pushing stuff to their limit. So we introduced this 1" thicker HiRam cooler for those of you who like to push things and have the room to fit it. Designed to mount to intakes utilizing the Holley Hiram flange pattern. The integrated sheetmetal plenum saves 2" of vertical...shearerfabrications.com
Low Profile HiRam Cooler, 1800hp
This Low Profile cooler saves tons of room with no performance disadvantage! Utilizing the same core as our 1800hp HiRam Cooler. We weld a sheetmetal plenum with integrated throttle body flange onto the topside of the intercooler. In comparison to the sandwich intercooler with the cast lid this...shearerfabrications.com
I already have the Holley flange to mate the above to on hand but first looks tells me the bottom intake is going to be too tall so I will shorten the runners some once I get the measurements right. later today I will make a firm measurement to see what my max room is..
I'm thinking cutting 2" off square to the top, ( red line ) or maybe cut the blue line, both should give me room to form the plenum and have that large enough..
