FellowTraveler
I had already been contemplating some sort ram air setup for the cooler, and I like the way you did yours, and will probably make something similar. Before adding a deflector behind it, I think I'll see if the truck stays running cool without it. Thanks for sharing..
Matt
Under my Burb's hood there is little or no room for anything it's crowded dual alt's create heat and up front I have two P/S coolers, two trans coolers & the one in the rad, and an oil cooler, AC condensor and a CAC all of this combined with the GMT400 lousy aerodynamics makes for interesting cooling issues at speed. In all seriousness I had problems until the EVANS waterless coolant and the med truck fan clutch was installed.
What I found was when that cover (some call a skid plate) between the bumper radiator support and chassis rails was removed it allowed air to be forced up behind the radiator shroud which stalls the air flowing through radiator.
The space between the CAC & the cover is minimal and equal to the ducting intake area the low hanging rubber tam/air dam is what pulls the air down and out of CAC at speed the fogger is for low speed traffic stop and go to cool down IAT however a lifted vehicle can use fans behind CAC because of all the extra space.
