- Staff
- #21
If the pedal is going all the way down, check to see if your losing fluid. If you are you have a leak, if your not the master cylinder is shot.
I saved some manuals over the years, but wow, a kit instruction sheet! Your kinda scaring me pulling that out.
Bench bleed it REALLY GOOD!, do NOT turn the key on until you are CERTAIN all the air is out of the system, and don't use alot of pedal pressure when bleeding the brakes or else you can push air into the ABS system and then need a scan tool to trigger the ABS to do a bleed of it's system. The best way to bleed the brakes to avoid getting air into the ABS when replacing a master cylinder is to reverse bleed. Also make sure and run alot of fluid through the system to get all the old moisture contaminated fluid out.
