dbrannon79
I'm getting there!
Which u-joints did you use when you replaced them?
Wasn't me unfortunately, and it was the ungreasable onesWhich u-joints did you use when you replaced them?
Honestly after this experience, looking more towards the greasable kindFolks are saying the non-greasable ones seem to last longer, but make sure they are USA made.
Thoughts on the differential photos though sir?Folks are saying the non-greasable ones seem to last longer, but make sure they are USA made.
I didn't see anything out of the ordinary. just make sure it's full of oil and pay attention to the pinion to see if it's leaking. might have been just how the photo looked. doesn't hurt to check the oil every once in a while! even the transfer case too.Thoughts on the differential photos though sir?
The diff fluid was changed when i took those photos 7 months ago sir.I didn't see anything out of the ordinary. just make sure it's full of oil and pay attention to the pinion to see if it's leaking. might have been just how the photo looked. doesn't hurt to check the oil every once in a while! even the transfer case too.
when was the last time the diff oil was changed? most just keep topped off and forget it. if you have never changed it, I would think about that along with the transfer case lube too just so you have that peace of mind.
Better video of what im hearingA chirp wouldn't be coming from the diff since it's all in oil. but you would be hearing a growling or groaning sound from the diff. when I had the diff in my 95 gone through I paid right at $500 for them to replace the ring and pinion gears along with check everything else over. that was not including parts. I had gotten the ring and pinion kit here.
the diff might just need the pinion shimmed up if not worn too badly. I would have them check the u-joints as well.
