ak diesel driver
6.5 driver
Should be some 90* fittings that go right into the block
Yessir, ill be looking for steel or brass 45 or 90° fittings to put in thereShould be some 90* fittings that go right into the block
The kit I got for my truck came with elbows, IIRC there may have been 45s and 90s.Didn't come with the kit?
If ordering the 6.2 kit this is how it comes.Didn't come with the kit?
If ordering the 6.5 kit this is what it comes with.Didn't come with the kit?
Send that picture to Leroy in an email and I think He would add the necessary components to his kit to make it more adaptable.
I know the measurements to get the elbow fittings, im actually more pissed at what i accidentally just did right nowSend that picture to Leroy in an email and I think He would add the necessary components to his kit to make it more adaptable.
He may even mail You the components.
Not at allDidn't come with the kit?
Replace it with a hydraulic lineI know the measurements to get the elbow fittings, im actually more pissed at what i accidentally just did right now View attachment 95085
No leaks or anything but I am so upset, I really just HAD to accidentally bend it, its not fully bent, and again, no leaks, but ffs such an amateur mistake
This. 100%. The high pressure hydraulic line like used in heavy equipment that is multi layered will never kink, take decades to wear or fail.Replace it with a hydraulic line
Copy sir, so far guages show readings as it was prior to like changes, no leaks though, its nice having oil free fittings for onceThe smallest amount of oil on exhaust will burn off but smell up a storm the whole time.
Keep an eye on pressure gauge and frequently check oil level after this type work just in case.
