dbrannon79
I'm getting there!
for something you only need to use once in a while.  Amazon has one for a reasonable price.   just be weary on the cheaper you go the less of quality you get.  mainly the accuracy of the gauge.
this one seems to be decent.
 . Not!!! Took will,s advice and pulled the stat. crossover and started it up and boy there was an eruption off coolant coming out Of the driver,s side head cooling passage. Was not expecting that much maybe just a few bubbles. At least I know which side
. Not!!! Took will,s advice and pulled the stat. crossover and started it up and boy there was an eruption off coolant coming out Of the driver,s side head cooling passage. Was not expecting that much maybe just a few bubbles. At least I know which side . Still have to compression tests (Dry
. Still have to compression tests (Dry ). Run my borescope in the glow plug holes on that side, hell if I see damage to the top of the piston or any where else I shouldn’t have to pull the heads, new motor time
). Run my borescope in the glow plug holes on that side, hell if I see damage to the top of the piston or any where else I shouldn’t have to pull the heads, new motor time . Still have to pull the passenger side W.well to get to GP holes for tests. Got a question when doing compression tests. Can I pull all of the GP.s at once or only do one at a time And put it back in ( that’s what she said
. Still have to pull the passenger side W.well to get to GP holes for tests. Got a question when doing compression tests. Can I pull all of the GP.s at once or only do one at a time And put it back in ( that’s what she said  . I’ll keep u guys posted. Thanks Gus.
			 .    When back to HF and upgraded to the Master test kit w/ the extension hoses.     Will be getting back to it today.    Yea I was surprised how much coolant was coming out of the coolant passage on that side.      Maybe with luck #7 still has good compression.      My plan is ( if the rest of the cylinders test good?) try to snake borescope through valve guide to check for damage,     slap a head gasket on that side and recheck #7.    I’ll just be out gaskets and studs
