Potluckslammy
@Will L. excellent, detailed, and well considered post, as always!  Two things came to mind...if a wind speed meter was used in front of the cooling stack, behind the grill, would that not give the best representation of air movement?  Or perhaps, better yet, a meter mounted between the a/c condenser and the rad, with a remote display.  That way values could be recorded at idle, and at all engine speeds while actually moving, and under load.  Maybe three or four meters are needed, one at each position in the air stream?  Maybe this was stated, and I just didn't fully comprehend what was being read.
Second, measuring both fans under same conditions, calculating the difference between the two values, and then coming up with some kind of determination as to how much that difference actually impacts the cooling efficiency of the whole system.
And maybe it's apples and...not oranges....but maybe Red Delicious and Granny Smith? Because they both do the same thing, the same way....but there's a difference of diameter, number of blades, weight, blade pitch...and, as someone said, the blades on the plastic fan may flex somewhat under load, making it more or less efficient at different speeds. So, maybe...either one is good enough, so long as it works.
