thr464fuf
So here goes. I recently purchased a 2000 Chev 3500 truck. It ran perfectly when I bought it. Started to have the symptoms of a "bad" FSD/PMD. Stalling, hard starting when warm. I also recently had a very hard time starting the truck first thing in the morning an extremely cold days (-20). Now it is almost impossible to start first thing any day. I just replaced the FSD/PMD with a higher temp rated Dtech on a heat sink on the intake manifold #9 resistor I purchased through Accurate Diesel. I just did this yesterday. Truck ran great. Best it ever has. I go outside this morning and the truck is still a pig to start. I call a diesel repair shop and inquire about glow plugs, and they suggest I have a fuel backflow problem somewhere, ie air in the fuel lines somewhere. Does anyone have an idea of where I should start looking. I hear the lift pump running when I turn the key and have verified fuel to the IP by way of the valve. No noticeable vacuum when I removed the gas cap. Anyone else had this problem. Any help would be greatly appreciated.
