So the posts here have me wondering if the ABS light is related to my transfer case and no 4 LO issue?
I can't say for sure but the ABS is tied into the autotrac controller.
No 4 LO could be something else like the VSSB.
VSSB PIN IN/OUT 1999 GMC, 6.5TD, K2500, 4WD AUTOTRAC, BURB
Socket to VSSB has 9 pin locations, w/ 8 being used & 1 blank.
C-7: LT GRN/BLK input from vss to VSSB
C-8: BLK/WHT ground to engine
C-9: BRN ignition feed fused 10amp
C-10: WHT output to ABS
C-11: NOT USED IN DIESEL APPLICATION, otherwise it's DK BLU vss output vehicle speed signal to terminal F-13 @ PCM
C-12: PPL/WHT vss input "this is wire to which re-calibration unit spliced into"
C-13: BRN transmission output speed to terminal F-12 @ PCM
C-14: GRN/WHT vssb output to cruse control
C-15: DK GRN vssb output to speedo
