chewy
Hi guys. I have an 03 duramax. I had the injectors replaced at 70K (under warrenty) a few years back. Got 180K on it now. GM sent out a notice right around that time saying that the fuel filter must be replaced avery 15K mikes. Prior to my injector issue I was not aware of that and had 60k on the first fuel filter. When I started having problems, first thing I do is replace obvious things like filters. The truck would run fine but had no power. Anyway, injectors got replaced and problem was solved. 15K always seemed the a very aggressive schedule for fuel filter replacement. I still push them to 20-22K now without any problems. How often do you replace the fuel filter? Just curious at this point. Those filters are expensive!
