Chevydually
It starts beautiful idles roughly low power stalls even replaced PMD change ECM Changed lift pump changed IP any other ideas
Thank I am going to try that this weekend I drive over the roadSorry. Ss diesel is a rip off supplier.
Go to any hardware store, buy 6” long piece of 1/4” diameter clear pvc flexiable tubing.
On the front top of the injector pump is a piece of 1/4” fuel line that is the return line. Replace that with the clear line. Fire it up and watch for a stream of bubbles. It is normal to have 1 bubble traped in there, but a stream of them indicates you are sucking in air and would have to be fixed/ bled out.
