I think you would be fine as long as you time that IP. You are wayyyyy out of time, surprising it runs. You could verify the PO didnt put the wrong IP on there, the model 5068 being wrong.
Actual injection pump timing: 90.02 Deg ° - This should be close to 30 Deg, so you are 60 degrees out of time!!!
Cam reference missed: 8 Counts - You are missing cam counts becuase the IP is rotated too much or you have the wrong electronics (meaning if someone mistakingly put 5068 IP in)
Crank reference missed: 0 Counts
Fuel calibration: 135 Counts
Fuel rate: 11.25 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 10.94 mm³
Fuel rate - Maximum transient: 52.19 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 1.62 ms
Injection timing - Measured: 0 Deg ° - Your PCM is seeing 0 degrees when it want 15, so the stepper motor is not working because it cant do anything when IP is rotated out of its range
Injection timing - Desired: 15 Deg °
TDC offset: -0.7 Deg ° - This is likely bogus and you would end up with a DTC88 out or range error if you ran TDCO learn. This is just a stored value in the PCM that is static until the relearn is initiated
