BIGR
Lucky To Be Here
Just wondering if you guys would consider it to be acceptable to have to add (anti freeze) engine coolant (Dex Coolant) from time to time in our Duramax trucks. I have had to add engine coolant 2 or 3 times in the past year after the low coolant light came on. More than once I thought I smelled anti freeze on the drivers side of my truck upon exiting. I got concerned about it and had the dealer to check for a leak when I had it there within the past year. Of course they claimed that they pressure tested the coolant system and could not find any leaks. I thought maybe I was just smelling something else, but if I am having to add anti freeze from time to time, I am thinking it is going somewhere such as a leak.
As you now by my signature my truck is a 2006 2500 HD of course with the LBZ. It has about 69,000 miles on it. Is there a particular AREA that I might need to look at as far as a location where it could be leaking at?
