Edge Evo Race w/CTS
Marauderer
Grumpy Old Cur***geon
Powder Springs, GA
Got the EGT probe installed yesterday and just need to get the wiring faired in a little better over by the fuse panel at the drivers door. Climbed on the motor hard while out running some errands. Even on Level 3 is was impressive. I will wait until I have installed the Transgo Jr before getting on it hard again. I can see why so many of you have built trannys.
stacks04
McLovin
terryville ct
you can romp on her a little just be cautious in the 5-6 gear zone. Its amazing what a little more fuel and timing does to wake these things up right?
Marauderer
Powder Springs, GA
Go to page 9 on this pdf file and it gives the power gains per level.
  • product_variation-installation.pdf
Marauderer
Powder Springs, GA
I thought that would get a smile out of you Stacks. I will ave to wait and see. Next is getting the Tranny built and that is a bunch.
Marauderer
Powder Springs, GA
OK, tranny is built, Alligator Stg V with SunCoast 1056 TC. Now to move on to EFI Live. If i had it to do over with what I have learned to date I would have taken Stacks's recommendation and started wth EFI and not have gotten the Edge.
SfcJones
A(ACLU) SGT. SLAUGHTER
South Ga.
Edge released a feature that was compatible with EFILive to use the CTS Monitor to switch between tunes (Like you would on a DSP 5 switch) but it only works on the 05 and later Duramaxs.
It works fine on my LB7, Ferm built the tune for me for EFI and I loaded it up. BTW, Mine is a 04 LB7
BoostN
Staff member
Administrator
Tennessee
I should correct my post.. only works on LB7's and (04.5 - 05) LLY's.. last I checked.
Mad Maxx
See, what had happened was...
Long Island, NY
Yep, still like that. I had a kid try telling me he had EFI Switchable Tunes on his CTS (meanwhile, it was just a Juice WA) and he just didn't wanna hear it when I tried telling him it isn't possible. I guess he never talked to someone that knew more about these Trucks than him, because I heard from other people he had EFI on the CTS.
It's something with the Code & Algorithm in the LBZ and later Computers that doesn't allow the tunes to be DIGITALLY switched on the Fly, so we're stuck with the Analog DSP Switch.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
I think it had something to do with the keep alive memory. If they implemented it, it would go back to a default on each restart.
Mad Maxx
Long Island, NY
That wouldn't be much of a big deal though. So what? It goes back to stock and you gotta pick your new Tune every time you start up. Still doesn't cancel out the ease of being able to switch the tunes on the CTS and still ALOT easier than running the Wires and Pinning Out the Harness to get them in.
