bison
Ok fellows, gather around and watch us learn something about the internals of your IP
I took a DS4 5521 IP apart about a yr ago.Sorry no pics of that.
I managed to get my hands on a parts break down and spec sheet and some instructions how to stick the thing back together from a friendly pump mechanic.
Dismantling the pump is actually easy.
Lets start with removing the ESO + large spring, underneath is a plastic sleeve,and can be pulled out with a hooked tool .
Remove the fuel intake nipple,then take the IP cover off,mark the OS location on the cam ring and remove the hold down bolt and the OS.
Next,figure out how to hold the hub without screwing it up and remove the nut, use a suitable puller and pop the hub off.
Note: if the pump can be turned easy by hand CC rotation,then the transfer pump is prob weak/worn or the key locking the pump hub to the input shaft is sheared off.
Remove the 3 bolts around the head and pull the head out of the housing,it'll come out as a unit.be carefull not to loose the 4 plungers in the rotor underneath as it comes free
Store all parts in clean diesel fuel,rust and dirt is your enemy.
remove the stepper motor,and the advance cover with the spring.remove both side caps(there is 2 springs on the PMD side behind the cover) covering the advance piston and the plug in the bottom of the housing.Now pull the pin holding the advance piston to the camring out trough the hole in the bottom( a small magnet is helpfull).Push the piston from its bore(note wich side is to the camring).
Remove the wavy spring and the camring from the housing.
Remove the rollers with the shoes from the slots in the shaft(keep the rollers with their respective shoe's).
Remove the 2 bolts (outside of housing)holding the transfer pump in place and bump the shaft and TP as a unit from the bore. Be very carefull of the encoder/datatrack ring.
Set the shaft on end and remove the snap ring,the spacer and the small rollpin from the shaft(put a fitting drill bit or wire in the rollpin before using the pliers to pull it out, as the kit comes convieniently without it).
remove the 5 bolts holding the 3 pump segments together and lift the top 2 parts off( leave the middle section with the vanes together) .Remove the key and the bottom plate with needle brg.
Use a fitting socket with extension and a hammer and bump both seals and the brg out trough the hub end of the housing.
The pump is now apart.
Onto the head.
Remove the 4 plungers, 2 long,2 short.
Remove the little screw and clamp holding the FS in place.
Turn the FS CC wise off the head( may need to make a tool for that,will be shown later)
remove the crimp ring and the ring holder,push the rotor up from the bottom and remove the 2 keepers with their pins,be carefull they are small,remove the rotor.
Pull the spill valve and the spring out of the rotor.There is 1 or more tiny shims in the bottom of the bore,make sure you get them all,they are crucial so dont loose them.
Here's a pic i took from the web that shows all the parts of the IP minus the housing.Prob illigal to post it :smile5:
you should maybe refrain from posting to this tread till i'm done,so we can keep it all together instead of it being strung out for 1/2 a ml.
more later
Onto the head.
more later
