Twisted Steel Performance
Does a charge air cooler really help make more power?
There is no dumb question...I have always wondered if a charge cooler helped anything or be worth it for our rigs in a stock setup (GM turbo and all) but was afraid to ask.
And the MG guys, installing a 3.8 grand national engine with turbo, mounting the turbo in the trunk of the car cause they didnt want to carve into the fire wall.as for introducing a lag or too large of a charge cooler, I have seen guys use or recommend the cooler from a dodge cummins. I'm curious if that would be too large (take too long to "fill up and pressurize") and cause a lag with a stock setup. also considering the amount of room our trucks have for adding one in the mix. I might do some digging around for what might work as a remote mount. maybe one from something like a Jetta would work fine for a stock setup.
I have one from I think a Volvo (don't really remember) that I am going to try some day.as for introducing a lag or too large of a charge cooler, I have seen guys use or recommend the cooler from a dodge cummins. I'm curious if that would be too large (take too long to "fill up and pressurize") and cause a lag with a stock setup. also considering the amount of room our trucks have for adding one in the mix. I might do some digging around for what might work as a remote mount. maybe one from something like a Jetta would work fine for a stock setup.
A picture if You could would help a lot.I have one from I think a Volvo (don't really remember) that I am going to try some day.
You bet!A picture if You could would help a lot.
