Matt Bachand
Depends on the 6.5
Damn, I thought the site was down all week and I missed out on great excitement in this thread.
INdeed, front sender and rear sender only give info to the balance module.
Balance module reads both, and energizes rear xfer pump when front is lower than rear by 2 gallons or so, and fills it about 2 gallons higher, this ensures rear runs out first.
Then the Balance module (which is a computer board inside) I think takes an average of the 2 tanks to send to the gauge. This is all based on the info I've dug up, not sure if facts or not.
However, I am unable to read the purple output wire as ohms to my fuel gauge.
Nothing in the above tests mentions I should be able to though, something about a wavelength signal or something?
Look forward to your next post Hydruak.
Also, when your rear tank is empty, can you please unplug the balance module and check for ohms on rear signal wire? (2nd one in, next to pink +12v).
And if you could, i know its harder, check the rear tank wire when its plugged in. Once again when tank is empty.
Also, can you check your front tank for OHMS, and fuel gauge reading (if its working), Both unplugged from the module and plugged in? See if they are the same.
Thank you very much, and welcome to the Site (and my lonely thread!) Glad to have some more peeps in here! I'm glad my research has helped you. And I don't mind being called mark, I've been called MUCH, MUCH worse
