jmiller
Recruit
I caught a couple deer last fall, one of which snapped my oil cooler. In which I pumped all two gallons on the ground.
After bypassing the oil cooler and dumping two gallons in the pan, I had good oil pressure and drove it.
Fast forward the last 10,00 miles.
I've been watching the oil pressure pretty closely. When its hot and idling, the pressure is usually around 35 to 45psi, at cruise 55 to 60psi.
Last week, I started hearing a new noise. Is sounds like a thumping sound that is isolated to the right bank. Real soft, but noticeable. Friday night, Idle oil pressure had dropped, to around 25psi or so. I'm thinking tow? I make it home, no real change in the engine sound but a "C" load of concern. I started the engine, cold oil pressure is normally pegging the oil pressure gauge. Even after the accident, it was still around 75psi or higher.
When I started it Saturday morning, cold oil pressure is around 60 - 65psi.
I'm doing the fix verses replace debate now! While that debate rages in my head, I'm thinking about doing a bottom end in frame.
Drop the axle, the pan and inspect / replace the bearings.
Thoughts / recommendations?
Bearing recommendations? Clevite, King, Seal Power?
I suspect the noise is from a piston contacting the head, if a bearing is spun, should I pull and replace that piston?
Are the bottom end fasteners TTY?
