Serpentine or v belt driven?
What thermostat crossover, if dual is restrictor in place?
What thermostat(s)? (AC Delco seems most reliable)
Heater hose circuity (most be constant flow, never blocked)
Having low coolant warnings well worth it if not stock in your application.
Being addicted to these engines, there is more to consider but not directly related to the head question.
permanent fuel pressure gauge tapped at ip inlet.
Ensure front starter bracket in place.
100,000 mile max on balancer
Always adding lube to fuel
Etc.
Many people get under 100,000 miles, and many get over 300,000 miles. More mpg; more power is available safely but depending on use and return if it’s worth it. Knowing how to set up as complete package is the key.
