DieselSlug
Good Morning Guys,
Our trusty 2004 3500 Dually got towed to our shop yesterday. Driver stated RPM's were rising on a highway drive to the jobsite. We checked the truck when it came in and the fluid was way over full. Supposedly the driver added some transmission additive in an attempt to fix.
This is a company truck with Reading box so its ROUGH. It has over 400K miles on the odometer.
I read the codes today:
PO872- Trans E solenoid.
PO335- Crank Sensor.
PO380- Glow System.
PO404- EGR.
PO700- Gen. Trans Malfunction.
P1093- Emissions.
P1404- Emissions.
So obviously the truck has had several outlying issues and was just driven as is, however the trans now shudders as you drive it. I'm assuming its in limp mode. We will be taking it over to a local shop we use to see if it can be reasonably fixed (for a rotted 04 w/400K miles).
We brought it in thinking the trans is going, however it seems like it may be a sticking e valve? Any experience guys?
PO380- Glow System.
PO404- EGR.
P1093- Emissions.
P1404- Emissions.
