Code
Already ordered, Its a 93 century special w/ 3.3 v6 4 door. No clue why he likes this car so much. It’s alright but nothing special imo.
Apparently this tensioner is becoming a nla part right now. Rock supplier is discontinuing, autzone has 1 in the entire state of Nv. None of the other regular parts suppliers have any availability.
Thanks for the offer though!
This 88 Buick is a POS for a vehicle. The lectronical windows barely moves when the button is pushed. RR window the regulator or some such is busted, window gets crooked then binds and has to be helped up.
The wifey used this for her DD and beat the crap out of it. Leaked oil bad so pulled the engine/transmission and resealed them, she just would not give up this car. While engine out pulled the crank and had it polished. New bearings, timing set and oil pump.
Then she got this Toyota thing. Another fortune spent doing the maintenance and fixing on that POS. Did You know that these little four cylinder engines will not run at all if the plug wires is in the least bit bad ? Never seen the likes of that before. So now that little pig is running real good.
Now I have too much invested in that puick and it runs so good that I wont get rid of it. The paint is faded out and rust showing through. Nasty bad dent RR door but in general the body is straight and it still has the hood ornament that people keep trying to steal. Every once in a while the ornament will be unwound and laying limp on the top of the radiator body support. They can never get it that last curl or so of spring so that it will come off. I wind the tension back tight and it once again stands proud.
Little car the body is solid and strong and dont rattle. It loves 75 MPH and uses no oil. And so now it is me that wont let it go. Been mighty handy having it while my truck is laid up, waiting for the back to heal.
@MrMarty51 on those windows that dont move well:
Use silicon spray on the tracks where the glass runs- it lubricates well and helps. If willing to pull off door panels, spray liquid graphite on the cables of the window regulators. Operate the window up and down to get all the cable. The next step beyond that is removing the motor assembly that drives the regulator, clean off and fresh lube on the gears- the grease on those will be all dried up and crunchy by now., and in your climate something a little lighter than the original grease would be good- remember that grease had to not go liquid and drip out for places like mine and phoenix- so. In the cold it is like mud at best when new.
Yes this goes for the gmt400 or any older windows. Man I miss the big metal X regulators- 3 pins and a couple rollers. 1904 windows like that still work.SMH
And that I shall dooooh.
Except remove door panels, at least not until the doc gives me full release on the back surgery.
Anybody have a current Rock Auto discount code that may be good out through like the end of October? I get their monthly emails, but I'll be damned if I can find a discount code anywhere in it, even if I go to the web version. The code they sent me with my order from them back on 8/8 expired last week, 9/8.
Here’s mine. It expires 10/13.
243622551124919374
Thanks, Nate! I'm looking at having to replace the passenger side CV shaft on my 2005 Camry due to the dreaded steering lock turn CV ball rattle (162K miles on the original shafts) and know that I should just do them both at once, so I will. Just need to do them before winter hits and I can't work outside in the driveway to do them. I've already asked my go-to mechanic what brand he uses in his shop and he told me he's had no problems over the past few years with GSP brand shafts - they're 100% new construction, nothing "remanufactured" like Cardone's or a couple of other brands. RockAuto carries the GSP axles for my car, and amazingly enough, even with their shipping charges, they're significantly cheaper than the lowest priced GSP axles I could find on eBay with free shipping, that's unusual! Like my KYB struts were cheaper off eBay than they were RockAuto - mainly while Rock had $100 off a set of four struts, they only carried three of them for my Camry, even trying for V6 vs my 4cyl, looking for Lexus and other model years in that generation Camry.
I used to get those, but haven't since July. I bought a pair of rear brake drums on clearance for the Camry from RA beginning of August, never received a new Discount Code from them since. They "claim" to have a Discount Code in their monthly newsletter email they send, but I've never found a code or link to it in either the email or web version of the email. Just promos for that months "deals", the story of somebody's goof up on their vehicle, and the trivia question, but never a Discount Code.
