Weight: 185Lbs/82 Kg
Length: 29 inches/74cm
Width: 22 inches/56cm
Height: 20 inches/51cm
Compressed Air Capacity: 24 SCFM/11 lsec at 100 psi/7 bar at 8 gpm/30 lpm
Pressure Range: 1000-2000 psi/70-40 bar
Flow Range: 7-9 gpm/26-34 lpm
Optimum Flow: 9gpm/34 lpm
System Type: HTMA Type 2
Motor Porting
Inlet: 12 SAE O-Ring
Outlet: 16 SAE O-Ring
Air Outlet: 1/2 inch NPT Pipe
Motor: V-360C Timken Bearing 2-5/8 X 2
You could probably feed your turbo with it for instant boost!
