BigBlueChevy
Compression Ignition Addict
I started tearing down the old girl this weekend for her buildup. After a seal failed on my drivers side rear axle and took out the spindle I decided there is no time like the present. I have to say I'm really excited to start. So far these are my plans for the buildup, in no particular order:
-Exhaust is getting completely finished. All 4" SS tubing from front to back. A mechanical cutout opening under the bed for when I decide to run my canopy instead. Dual 4" stacks are being traded for a Single 5" Aussie.
-Fuel system is getting a tune up. The draw straw/ sock setup is being shown the door. Sending unit is getting replaced while I'm in there, and tank is getting converted to bottom sump for future upgrade purposes. Stock LP is getting booted as well in favor of an Air Dog unit. I'm sick of that thing failing.
-Frame rails are getting coated. They will be pressure washed, wire wheeled and sanded for a rubberized coating. There is no rust and I'm not about to let it start now.
-Air system is going in. Tanks getting mounted in place of old spare tire carrier, with a 100% duty cycle VIAIR compressor and Bendix filter unit. Air hookups will be routed to the front and rear of the truck with standard quick connect fittings.
-Suspension is getting the biggest work. Front axle is getting replaced with a kingpin Dana 60(FINALLY!!!!!), Rear axle is being replaced with a Dana 80 and a Divorced NP205 transfer case will be used to finally give me full 4 wheel drive. 205 is being converted for twin stick operation.
-Air intake system is getting redesigned. Removing the K47 airbox and going to design a new intake that will have the battery and air box switch places. Similar to the DMAX style. I'm done waiting for Bill's aftermarket unit.
-Build front bumper. Stock bumper is getting replaced with a built one. Which will be centered around a PTO driven Winch that I stumbled upon
I'm sure other things will come up along the way(they always do) but for now these are my plans. It won't be the fastest build in the world, but when its all said and done, Big Blue will be more than capable at handling any terrain, in any weather, and with no concern of whether or not something may break doing so. I'll have so teaser pictures up tomorrow. Night ya'll.
:coal:GMCtrk:
:coal:GMCtrk:
