Hi, I've been bashing my head against the wall on this and getting nowhere. The truck is a 99 Hummer, it's OBD2, new P400, new DS4 IP, the ECM has a Heath tune, and I'm using an AutoEnginuity scan tool.
I used Time Set to get the base timing set to 3.5*. I read somewhere that on OBD2 systems, Time Set doesn't work anymore and always just shows 3.5. But I was able to see changes in the base timing with small adjustments to the IP, so I gotta figure Time Set is working and my base timing is locked in where it needs to be.
The problem is the TDC offset. It's at -1.58 right now, and I haven't been able to clear it with KOKO, and it doesn't change appreciably (got -1.50 once) if I do a TDC Learn through the scanner. I'd like the Offset to be around -0.75, which is the top of the range suggested by AM General - my concern is running too hot if the Offset is beyond that since the Hummer cooling system isn't the best one ever hooked to a 6.5.
Engine temps were 170*+ for all tests, it starts good and sounds great. I can see the timing change and hear the engine response during TDC Learn so I know it's doing something. But why is the Offset so far out of the -0.25 to -0.75 range, and how do I correct it without destroying the base timing which seems much more important?
