turbopower6
Hi Folks,
The laughs keep coming.....Soooo-ooo after replacing the injectors with new Bosch from Bill Heath , new Durotherm (sic) glows while in there as well, new PT Wiring glow harness and battery cables, all new belts and hoses...including that bastard lower radiator hose that was...wait for it....I believe the original hose after 192,000 miles I figured I would be issue free for at least a while.
Pinch me...I AM delusional...as my wife informs me!
So here we are about 1,000 miles down stream with all systems working perfectly and the truck performance improved in a big way, smoother...more power...quieter (?) ....starting quicker and cranking way faster....she throws a PO236 code?
So I check it, make sure I have strong vacuum to the waste gate solenoid and the waste gate is moving freely. I then clear it drive a few more days...boom another P0236 code again pulling a grade.
This time I looked at the freeze frame and I am scratching my head:
Cal Load (%) 82.3
ECT (°F) 190
ENG RPM 1918
VEH SPEED (MPH) 24
IAT (°F) 145
What does this mean? If I understand the situation, I am guessing the turbo boost is not meeting the PCM expectation under load. Could the waste gate be slowly opening and bleeding boost under a demand for boost scenario? I am pretty confident my vacuum line is in good shape to the solenoid but I could check it more carefully and throw a vacuum gage on it to see where we are at. The vacuum pump was replaced before within about 10-15,000 miles with a new GM part.
I know we have guru's on this site who will be able to weigh in and help we get to the bottom of this.
Thank you...AArggh!
Chevy 6.5 Diesel Suburban is "ADVENTURE" spelled backwards!!
Now...time for cocktails and a debrief.....
Regards,
TGK
Cal Load (%) 82.3
ECT (°F) 190
ENG RPM 1918
VEH SPEED (MPH) 24
IAT (°F) 145
Thank you...AArggh!
Regards,
TGK
