A/C Fan issues
Rodd
Recruit
Antelope, CA
This is on my 98 suburban. I have had problems with my A/C fan/blower for a couple years now. When the fan is turned to off it stays on low. Occasionally high will go off and not work but the other speeds will. Also when I hit a bump hard enough the fan will go off on all selections. When the a/c button is on the compressor is on even when the fan isn't blowing. I took the little module off of my 95's fan switch (since the motor is out of it and I know it works) and put it in the 98 and the fan wont work. Is there something else I need to look at?
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
The blower switch and pigtail probably need to be replaced. And the 95 control panel is wired differently than 96-00. You can pop the control head crossing the wiring.
NVW
Castor, AB.
Try putting the old switch back in. Sometimes it is the connector or connection.
Rodd
Recruit
Antelope, CA
The little black connector that I took off the back of the fan controller is the same part and has all the same pins. Is that the blower switch that you are referring to?
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
The blower switch is part of the ac control head. It sends the power to the fan for each fan speed, and has a pin that turns the control head on. There was a tsb about the blower switch causing this problem. And the wiring looks the same between 95 and 96-00, but 95 is a 1 year only.
Rodd
Recruit
Antelope, CA
Does this mean I need to replace the complete control unit? Here is the link to it at rockauto.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
No, you can replace the blower switch seperately of the whole control head. I just picked up 2 blower switches because my 99 Tahoe wouldn't shut the compressor off at all.
Rodd
Recruit
Antelope, CA
Where is the blower switch located and what does it look like. I just tried to pull it up on rockauto and it brings up a lot of switches but not a blower switch.
Rodd
Recruit
Antelope, CA
That is the part I pulled out of the 95 and replaced in the suburban. I'll order a new one and see if it fixes the problem.
THEFERMANATOR
FRANKENBURBAN
Staff member
Lead Moderator
ZEPHYRHILLS FL
You may need the pigtail as well. It is pretty common for the pins to get loose in the plug.
