rlb
Posting this for my Uncle...
He has a '99 suburban with 350. Its the "spider" fuel injection. 300,000 miles.
Was running okay. Now cranks but no start. Turns over, sounds normal, won't fire at all.
Fuel Pressure good, 60 psi when cranking
Good spark on one plug
Compressions 1, 3, 5, 7, are 100, 160, 175, 85 psi
Compressions 2, 4, 6, 8 165, 185, 120, 175
Popped and spit when sprayed with starting fluid. Obviously has one bad cylinder, but should run. Next steps? He is thinking the ECM is bad or distributor timing jumped.
