OBE
Low mileage truck (97k gently-driven)
This truck has run perfectly for the two years I've had it but this Winter it began running rough on cold mornings. After it warms up to operating temp it's fine-as-usual. I read the codes and they are as follows:
P0172 (System too rich Bank 1) ...
P0300 (Random / Multiple cylinder misfire detected) ...
P0337 (Crankshaft position sensor A circuit Low) ...
P1345 ... Crankshaft position CKP Camshaft position CMP correlation.
Can anyone offer some guidance? I will move this to the correct forum if someone will direct me.
Will L. ...Well I can see the chain of events for the codes:
The 2 crankshaft codes are hinting to the issue i think. Then too much fuel dumping because of it causing the rich code and that causes the random misfires.
The cam and crank timing are reading too far apart. You need a scanner that can read the cam (cmp). It should be from -02 to +02. Anything out of that range and you need to figure out why it is out of time.
If this were an older non electronic small block you would just move the distributor to change the timing.
Was any work done on it back then when the issue started? Real high miles where the timing chain could have stretched?
It (problem) started in the cold... something to do with enfiching fuel via temperature- but I would think other codes would be present also...
Thanx, Will...I haven't had to do anything to it other than the trans which went on me and had to be rebuilt. Also had the worn brake line which I replaced. I had been talking about the way it seems to "use" coolant. I ran it real hot one time 'cause I was on the interstate and wasn't watching the temp gauge. It "seemed" to have come back from that, though.
I carry extra coolant with me and I watch the reservoir which calls for a drink every few weeks. I suspected the intake manifold gaskets allowing it to burn coolant since it never has any spot, on the ground, under it. Then one day I left it running while I ran into a place and when I came out I noticed dripping from the area at the back of the motor. It doesn't do it all the time, though, but it's getting rid of coolant from somewhere. I don't have a lift so I have trouble looking for the leak. I'm also 72-years-old, fat, and not very flexible anymore.
I went onto OBD-II Trouble Code dot com and got printouts of the codes. P0172, P0300, P0337, P1345. In those explanations they allude to oil or coolant getting onto the sensors as a possible cause. The truck began to run rough on early morning cold weather starts but when it warms-up it runs as good as ever. This truck had about 70k on the odometer when I got it and it's in the 90s now and the engine compartment looks like a new vehicle, so I doubt if engine wear could be the cause.
(please excuse the posting of an ongoing exchange...I had posted it in the wrong place and decided to move it)
