95 6.5 Turbo vs. 96 6.5 Turbo
The wastegate has to be before the turbine, so it cant be in the turbo elbow. Both must exhaust into the elbow prior to hitting the turbine.
Wrong. Not sure where you heard that it's not in the elbow. It most certainly is in the elbow.
That's a GM-8 exhaust housing on the left. In Bison's "rebuilding a GM-8 turbo" thread you can see a shot of the exhaust housing/elbow and you can see the WG is in the elbow not the housing.
Closeup.
OK, so the gate itself is hinged in the elbow, so it cannot be used on earlier models.
The actual waste path always begins preturbine, and the opening is in the turbine housing. Did GM do that to use a larger turbine in the GM8?
Hmmmm....That's a good question buddy. I don't know.:confused:
I think it was for better exhaust flow, but don't quote me on that. None of the GM-x series are great in the exhaust flow dept.
Hey Matt, remember the guy who was leading us on with all his truck fixes and ailments? Well he stated he had his turbo tested at a diesel shop in Olathe. I just asked the question about knowing off hand if a turbo is OK, then I just realized Olathe is only 23 miles from my house. I could call up there, to see what it cost to get my turbo tested. I wonder if it really is $75, or if I need it done twice?
