07HDClassic
I have a friend with a 1996 6.5 in a 3500 who found a replacement turbo off of a 1995 2500 Suburban. From what I have found, a 95 turbo is different that a 96 turbo. Is it possible to make the 95 turbo work on the 96 truck?
turbos bolt right up and the only difference is the wastegate direction
No need...If you have a vac system just plug it in.....Or make/change the TM.
If the impeller has virtually no shaft end play it should be good.
