So how do I know which resistor I need to use? Currently have a #7 in there.
Use the #7. At the end of the day it doesn't matter because it simply doesn't change the fuel much. It does matter to be emissions compliant, but, not at any test we are subject too. A clogged air filter makes more of a difference than the resistor because a clogged air filter has failed me on a smoke measured "snap test" many times.
I forget emphasis on TOWING near, at and over the limits, in extreme temperatures of 121 degrees, on 7% or steeper grades that go for miles, with an umbrella wedged between the seat and the throttle because the damn cruise kicks out at 16 MPH below the setpoint.
Thus my comments on a specific grade that I refer to as "6.5 killer hill" as it's scattered some 6.5's pretty badly and hurt some other stuff. Yeah, EGT monitoring is a waste of money and unneeded heartburn on this engine. You can see black smoke out the exhaust in your mirror (adjust it, eh) and ECT starting to push over 210 means back it off. With a waste of money EGT gauge I pushed it to a sustained 1550 ECT, towing, on a grade, with minimal smoke, and ECT at 210. All It proved was the turbo didn't melt down and a turbo blanket will indeed burn black where it touches the turbo. Oh yeah, Buddy who was sitting next to me was white as a ghost when I read off the EGT that high because we were in the middle of nowhere while "Busting" the EGT myth. We did turn down the tune because there is no real need to be that hot as it doesn't help power.
My avatar pic burned #8 down just fine for the prior owner with a bad injector and EGT reading normal in the crossover.
Run high EGT on a specific year Cummins 5.9 HO and it can drop a valve seat. So EGT advice is Engine Specific. I would say it's turbo specific as well because the GMx turbo holds so much heat in the engine, but, we ignored 1450 EGT every day 550 miles a day delivering a trailer full of parts all over AZ. This underpowered engine has to work pretty damn hard out here towing. Even unloaded vehicles regularly "Halt and catch fire" on the grades I refer too. They also burn to the ground as fire support is so far away.
Even a stock power setup with everything working means you SHUT IT DOWN at 210 ECT. You are less likely to have trouble in light duty use. Running flatlands or DD grocery getter can hit one go over 210 when something is wrong. Asking for towing or loaded power increses your odds of hitting and going over 210 ECT.
