turbonator
I like how they are still using the OEM damper in the pic.... What?
That is the ideal setup however if it were CAST IRON...(maybe it is?) But way better than nothing. Or angle iron.
The rear cap should be a part of the assembly too IMO.
That is the general idea of a P400.
Add a steel crank and never look back.
it is more likely that AMG used his idea as that was made in 2004 i believe....i dont think it is cast iron, but it does not matter, as it is coated to mimic the properties of cast, in fact all the inside of it is coated.... it is done by swain tech....
