Hey guys quick question. So I finally got the truck running after installing the HE351VE on Friday. Definitely still need to work some bugs out. I definitely noticed an improvement in the low end snap, but it still isn't performing where I want it, although my custom upper intake I made really sucks and is leaking boost, so I need to redo it. The EGTs aren't what I want. In fact they are a bit higher than my GM-3. I must not be controlling the VGT quite right. Yesterday I took it on my "performance test" which is starting at 55mph on a hill near my house and seeing how fast I could go at the top. With the GM-3 my record was 64 mph at about 850 degrees EGT. When I did the test yesterday it fell on its face. Hardly 60 mph at 900 degrees. I couldn't get it to reach 10 psi. So I have some things to work out.
Anyways, here is the big question. Yesterday my water pump went out, so the truck sits again
so I am going to do my cooling upgrades now. 2000 year pump and fan clutch. Here are my questions....
It looks like my 6 blade fan will not fit the new clutch, so I need to get a fan ASAP. I found a place where I can get a fan for 2002 duramax for $50. Buddy, you mentioned, it can be "coerced" onto the 2000 year clutch. How hard is it to do?? I don't mind having to do some "coercing".
I am looking at an online catalog for the clutches. One says "reverse rotation severe duty" Will it work??
The 2000 year pump will bolt right on my truck correct?? I kinda need to figure this out quickly so I can get the stuff ordered today, as I need the truck on Saturday. Thanks guys!!! I will also be ordering a 190 degree AC Delco T-stat.
