6.5TD motorhome starting problem
The lift pumps that went on the 6.5 rigs were designed for an older injection pump that didn’t require as high pressure. GM was pinching pennies and kept making tiny improvements to the lift pump, just enough to make Stanadyne who make the injection pump honor their warranty while the rig was in its 3 year/ 36,000 mile warranty.
GM didn’t care when the liftpump dies because the engine still starts and runs. The majority of owners don’t notice the longer start times, the loss of performance going down the road. So they profit the difference.
It is only from fleets that own huge quantities of these rigs and owners that have a descent mechanical ability (many are mechanics as a day job) that it is learned how bad underperforming the factory lift pump is.
The injection pump is ballpark $1000 plus labor- so a really expensive lift pump becomes hard to justify. Newer diesels where parts and labor run around $15,000 the price makes sense.
6.5 pickup guys choke on the idea of $800 for a lift pump- especially considering resell value of the rig. But when the rig has value of $40,000-$100,000 like a Hummer… and you ever have a breakdown, tow bill, or even think about it again- many hummer owners easily justify it. An RV… very situational. It might be a $150,000 rv, but if it is only driven 2,000 miles a year and a HUGE FACTOR is how much labor to replace the injection pump - makes the difference.
I once bought an RV just for the engine. It had a bad waterpump- the weep hole was dripping. The nose of the rv had to be literally cut off to gain required access. Estimated repair cost back in 2002 was $24,500 average- he had 4 quotes and all were within $1100 of each other. It sat for 5 years before he gave up and sold it to me for a couple grand - I removed some of the interior stuff = tv, 2 recliners and delivered them to his house. I took a forklift and ripped the body to shreds and into a dumpster. Chopped the frame with a torch to roll out the engine and transmission. Everything else went into the roll off dumpster.
Some RVs are easy to work on.
Labor for replacing an injection pump is double to triple on a hummer vs a pickup.
Van labor is triple a pickup, if it has 150,000 miles it goes to a junkyard, regardless of condition.
Some people keep buying the poor working factory lift pump and just replace it every year. My hummer is the older injection pump that only needs 5psi- so I replaced my lift pump about every 1.5-2 years. But the lift pump used to be $40.
Now $110 is about right. But the diesel fuel now has ethanol in it. Look at your gas station for the word OXYGENATED that is ethanol. It shortens the life of these pumps, and higher percentage does it faster. 10% means about 1 year- and it doesn’t matter how many miles. Once the fuel soaks into the plunger of the pump it is eating it slowly. Taken apart and soaked in the fuel you cant tell the difference until you use a magnifying glass to see the edges getting messed up. It simply rots it away.
If you dont measure the pressure AT THE INJECTION PUMP - you wont know what is really happening. I have had the argument with literally hundreds of people over the decades. But I am the guy that the dealership and small shop mechanics called and paid a consultation fee to when they could not fix a 6.5 rig. I was once flown to Texas from Nv where they paid their mechanics and had 8 trucks still under warranty all set up in the mechanics bays. I wlaked through one at a time and did the diagnostics on trucks they took back in on trade and lost money on each one. I told them over the phone what I am repeating to you & many others here. Then when I got there, they finally did what I said. Half of them were fixed and on the lot for sale that day as good reliable trucks- they others took a week for parts to get there.
I’m not being picky. I don’t care when people don’t listen. But I tell the same lessons to people over and over again. Eventually some listen and are happy. Those who don’t can just keep throwing money at it and sell it later in disgust.
To be clear- I don’t think your hard start will be fixed by improving the incoming fuel pressure at this point. I think your injection pump has already suffered some internal wear it shouldn’t have. You can slow that progression by putting on a Fass or equivalent pump and getting the pressure adjusted to higher pressure meausred at the pump never exceeding 14 psi, never below 8. The wear on yours will determine where the best exact level is. But adjusting and testing as something most dont do. Adjust, test, record results. Repeat. Examine the numbers and make the final adjustment. Once in the 8-14 range, the gains to get it exactly at say 11 psi as an example- are really minor gains in power. But that gain is also the efficiency so it MIGHT help mpg- rare but might.
If you did all this - the start time will not improve by 1 second crank time, maybe 1/2 second. This is for long term health of the rig.
Your problem sounds like glow plug issues. It wont save you time because the best plugs require longer glow times to get to heat.
Best thing for faster starting in your case long term is a Powermaster 9052 starter.
You need to ensure battery cable conditions and size. Ensure battery condition and size. Ensure clean connections.
Will L. and Everybody: I let the fuel sit in the container for three days...clean...no signs of anything.
Will L.: That is quit a write up about the 6.5...I read this over and over. You must eat, sleep , and drink the 6.5's!
I believe the best tests (we've already done so far) were:
1. We did first - was plugging in the block heater for 11 hrs. and it started right up.
2. The test for the injection pump that was 5 1/2 lbs of pressure.
After these two tests - you thought they were OK.
You then stated that my problem was probably a glow plug issue. (I do have 12 plus volts to each glow plug.) That also tells me that these 60G glow plugs need a little more "heat time".
When I say hard to start- I am talking about the amount of time it takes after the glow plug light goes out. It takes 9 seconds to start. (I did this today)
Question: If so- would you suggest another brand of glow plug to try that would start like the old 13G's?
Thank you for taking all this time to help me with this project!
The fuel pressure is ok for it to start. You are probably starving the injection pump when on the highway. When you get back to it next season- get the fuel pressure gauge T at the injection pump inlet. Watch it from there. If at any time you get under 4psi- know that it is wearing it out quicker than it should. If you get to 0psi/ vacuum- you are doing immediate harm.
Also check the harmonic balancer and belt pulley in front of it. This age of the unit regardless of miles, I am 99% betting it needs replacing.
Unfortunately, the 60G are the ones to go with. There are others that will heat up a little faster but they can swell, even break off because of it.
Long term faster starts- remember the powermaster 9052 starter. It makes an amazing difference. Then just keep your old starter as an emergency backup up.
And yes- I spent too much time into the 6.5 world, my wife will testify to that .
Wire in a push button switch to the glow plug controller tee off from the yellow wire on the 5 pin connector to the push button switch, then the other side of the push button switch to a fused positive (perferably switched pos from the key like tapping into the radio fuse on the inside fuse panel) turn the key on and count the seconds the WTS light is on, as soon as it turns off press the push button switch and hold it for another 5-8 seconds then try starting and see if that fixes you problem.
one other thing is did you bench test the glow plugs before installing them? not saying any are bad, but it's not impossible to get one dud in the package now that everything is made in China. easiest way to bench test is with a set of jumper cables. clamp the ground cable to the GP body and hold that ground clamp in your hand. then use the pos clamp to touch the spade connector on the end of the GP and watch it glow red. you can time it there to make sure each one takes the same amount of time to glow, also with the 60g's you can hold it keeping it on and not worry about it burning out. just don't touch the tip until it cools, it will burn your fingers in a hurry.
when going back in with them, make sure the wire ends are a snug fit on the GP and not loose. if any are loose that is cause for a bad connection. just use a small pic or something to squeeze the terminals to make them tighter if needed.
If you have a amp clamp for you multi meter, you can place it around all the wires on the output side if the GP controller and read the amp draw when they are on. it should show about 90 amps. if it's only drawing say 50, then one or two GP's are not working/bad connections.
my bet is on them just not getting enough run time.
if this is the case and since your rig is a 95 (obd1) with an automatic trans, if we can find the components online (chip and adapter) I can program you a chip to replace your existing one inside the PCM that would keep the GP's running for a little longer. Free to program the chip, just need to find one since Moates has gone out of business and no longer selling the eprom chips or adapters. I have all the equipment to do the programming.
Oh Wow!! I just looked up and see Moates is back!!! the guy had retired and shut his business down sometime around or after Covid had hit. i just looked and he's back!!
Here are the two items you need for me to program you a chip to extend your GP time.
the adapter to connect the chip
and the chip you need.
PowerMaster starter will take it from 9 seconds down to 3 or 4.
I’m going to do a water treatment on the top end of the four cylinder thats in the MG.
Then change oil and adda can of restore to the mix.
They advertise it in four, six and eight cylinder enjuns.
I dont remember which size I got, I’ll have to look next time in the garage.
Yeah- that Restore brand is the one that had the third party testing on that showed it actually brought back some of the lost compression.
Using larger cans than called for doesn’t help - it hurts because too much of it gums up on the oil passages. So use the right size.
That I will check.
If I got the larger size, I’ll attempt doing the math, divide the number of cylinders by the ounces labeled on the can then pour in an ammount according to the math.
Long as I dont throw some alphabits into the equation I’ll do just phine. 😹😹😹😹
dbrannon79 and everybody= I already put in that push button and have 12 plus volts.
All wire ends fit tight and each wire checked out at 12 plus volts.
My rig is a "1996 with the OBD2 system".
I checked the Motes cite and it does not show anything past 1995- unfortunately .
