Ba_051
Well I recently installed a 6.5 NA Diesel into my old jeep trick and finally got it fired up after 3 weeks...
It starts right up, but you can feel a slight, but very consistent "miss" at idle... The truck bounces a little at idle...
It has true dual exhaust on it and the passenger side just blows a little black smoke on acceleration... Nothing at idle or cruising and no blue or white smoke...
The drivers side however blows very little blue smoke at idle, and belches it under load or even just revving it to 1500 rpm or higher...
When I crack an injector line, there is a very apparent change in how it runs (does it on all 8 injectors)
There is no blowby at all and I just replaced the glow plugs and injectors (before I swapped it in)
Idle oil pressure is about 70 psi cold and about 25 hot...
What could cause all the blue smoke when just reving it and under load when just driving it...
