Clear your mind of parts you want to replace and start over.
NO! it's not that - START OVER!
You have a weird sound, loss of power, and engine stalling. Throwing parts at isn't going to fix it and will waste money. Sometimes we get bad parts and start over the troubleshooting then. parts replaced 30 seconds or years ago do not give them a free pass.
By the book first you want to make sure you don't have air in the lines. You verify this by using a clear return line off the IP. Air would normally clear out, but, constant air is an issue and this is what the clear line tests for. Air leaks from a bad hose, rusted pickup assembly, etc. Air includes diesel vapor. A restriction in the fuel line will have the IP boil diesel in the fuel line. Kinked hoses, plugged tank socks, water in fuel are all restrictions.
A pressure test from the water drain port is in order. The Oil Pressure Switch that runs the lift pump goes bad often. The lift pumps IMO are the biggest turd supplied with these trucks 2nd only to the restrictive GM3 turbo. "0" is a useless reading as you need a gauge that reads a vacuum as well as pressure. You can snap the throttle open and hold the engine on the 3600 RPM governor and have 0-5 PSI. A vacuum is a bad sign. You need to hit max RPM as the IP bypasses a lot of fuel and even more fuel at high RPM. Idle readings are cute - but the real problems can show up at higher RPM. These engines don't start or run well without a working lift pump.
Assuming you don't have water in fuel or any fuel restrictions - aka getting 5+ psi at idle at the water drain we move on.
Check codes for transmission issues. No SES light comes on for any faults the 1993 ECM, 'transmission' computer, finds.
Look at the passenger side of the IP, injection pump. You see a lever on it from the throttle to a pin at the bottom of the pump. This is a timing retard lever for higher loads. With the engine at idle push this lever in at the bottom with a large screwdriver. The engine should start to run bad and nearly stall with possible white smoke. This somewhat verifies the timing piston in the IP is working - a common failure in these old DB2 pumps is for the advance piston to lock up. No change with the pin in is bad news - rebuild IP time.
Next is the dreaded difficult 'hot start' issue from a worn head and rotor in the IP. Again the above lift pump not working will aggravate the difficult starting with a hot engine. When the engine is hot it may be difficult to start like when your camper was installed. No glow plugs are used because the controller is hot and won't kick them in. Thin fuel from being hot and a worn head/rotor makes starting difficult: Long cranking or no start. Cold water dumped on the injector line side of the IP causing instant starting verifies this condition.
We have even more fun for 'stalling'. The idle speed needs to be set every 6 months. A light sensor digital tach with reflective tape is one way to set this. You adjust the screw in the IP when hot at idle to get 650 RPM. Then you kick the cold advance on and blip the throttle. Then you set the cold advance to 750 RPM. Hopefully the TPS doesn't need adjustment after that.
You do need to verify the cold start switch on the coolant crossover is working. As the engine warms up you will hear the rattle get less and RPM drop when it kicks off. You have to step on the throttle with the key on and engine off before starting cold to set the cold advance high idle - allow the idle plunger to drop anyway.
Next you can have a shop verify timing as the timing chain stretches over time and retards the IP timing.
From your description I suggest fuel delivery problems as described above. Oil use doesn't tell you anything. Worked hard like freeway speed with a sail like camper these engines can burn 1 quart (~1 liter) in 500 miles. White smoke after start-up is a cold engine and likely will smell like fuel. Lots of white smoke is likely a timing issue.
Last a bigger turbo gives you power over 2200 RPM.
The factory turbo becomes an asthma attack over 2200 RPM.
