VW_Lupo_TD Active Member Messages 1,046 Reaction score 20 Location in quiet Sep 10, 2009 #1 anyone ? i assume the same as 4LE80 but i cannot find that either.... thanks
THEFERMANATOR FRANKENBURBAN Staff member Moderator Messages 10,575 Reaction score 5,794 Location ZEPHYRHILLS FL Sep 11, 2009 Staff #2 I always just go around in a circle pattern and pull them up slowly and evenly and torque to 11 foot pounds I believe it is.
VW_Lupo_TD Active Member Messages 1,046 Reaction score 20 Location in quiet Sep 11, 2009 #3 circle pattern ? if i remember correctly that is not the way to go. i was assuming you should go from the inside out in a criss cross pattern. but if it worked for you, i guess your guess is better than mine ;-)
JiFaire Land Mine Finder Messages 11,364 Reaction score 8,883 Location Alberta, Canada Sep 11, 2009 #4 Most of the torque specs are i the 6.5 tech. library, thanks to Matt (Alberta Redneck)... here is the trans. pan R/R guide and specs from ARRC - Courtesy of BigArt). For other stuff, look in the 6.2/6.5 Technical Reference Library under 'Manuals' Hope this helps, Nick! Jim Attachments Trans Fluid Pan.pdf Trans Fluid Pan.pdf 67 KB · Views: 27
