Wilber, my 2cents not intended offend but to help: your input is always useable. If you say white and someone else says black, it is up to the person who owns the truck to figure out who to follow.
Theferminator's opinion is listen to a lot here because he has proven to be right almost every time he gives it. He has been a tranny guy for more than a day or two. I appreciate his help because he is always here to give it.
That doesn't mean I don't want to hear a different point of view. To me the more info the better, the. I can learn more.
Maybe a person doesn't want to follow his advise and would follow yours, but if your not here to have the debate with Ferminator to prove your point then the guys who need the help can only hear one opinion, right? After reading 2 or 3 differing opinions, a novice can then so more research on their own and figure out what is the best thing to do for them.
When I was adding the turbo to my truck I had to overcome signal for the engine speed to my TCM problem. Buying a controller was not in my economic capacity of the time. No one person had the cheap fix to my problem of the time, but using advice from a couple of different people and s little of my own creativity it gone done very well, and low cost. Stay around to help where you can, learn where you can, and make friends that you can agree with on SOME things.
Idk who has the better answer you or Ferminator because idk trans, but if he stays and you never help in the future it will sure look like you ran away from embarrassment...
Ferminator, I know I can't hurt your feelings cuz your level of skills and mine are obvious to those who read you catching my errors.
