btfarm
America First!
Here's a trick for getting the distributor drive tang in the right location. Assuming you know where the rotor should point at #1 TDC (and #1 piston is there), turn the rotor as you lift it out of the tang and drop it back down. That will move it 1 tooth. Repeat that until it drops where you want it to. Takes less than 2 minutes when you get the hang of it to go a full turn. Beats the laying across the engine with a screwdriver and flashlight trick.
On edit: Tim, you're this far. Get the reman unit. You'll be glad you did.
